I've been helping my neighbor with his pool, as he has no prior experience with one. It's an above ground with a 120v pump, which I'm not as familiar with. A couple days ago, I noticed his water level seemed low, and the pump looked to be having trouble maintaining prime (filter pressure was bouncing back and forth). I figured he would add water given the circumstances. He texted me yesterday saying that he had gotten home from work, noticed the pump was off, tried to turn it back on, but everything was dead. My initial thought was that the pump lost prime, overheated, and damaged the internals. I tried resetting the breaker, upstream GFCI, etc, but nothing has worked. When the timer is in the on position, I hear nothing from the pump. There is a power switch on the pump itself, which I also tried toggling. The pump is a Pentair OPT-NI-1VD (1 hp).
I went over there a little while ago with my multimeter and am very confused. I think the timer is an Intermatic T103. It has 3 terminals labeled A - Neutral, 1 Line, and 2 Load. There is also a green ground screw. When I test from line to neutral and ground, I get 120 volts. When I have the switch set to the on position and test from load to neutral/ground, I'm getting a value of 6+ volts. I'm assuming that's just stray voltage. I'm using a digital Fluke multimeter. I also unscrewed the back of the pump, and with the timer in the on position tested hot to ground/neutral. I'm also seeing a reading of about 6+ volts. I may be misunderstanding, but with the Intermatic in the on position, shouldn't there be 120v on the load terminal and 120v in the back of the pump? I really thought that this was a burnt out motor, but now I'm very confused.
