Opening pool after 2 yrs. Company comes and opens. They did but then we had to switch off pump because of massive amount of leaves. We finally cleaned the leaves.
But now water is green.
I know the DE filter needs back washing but the pump won't prime. So I am stuck.
I have never opened the filter before. Do I need to do that now?
The strainer basket fills only uptil halfway up( I did top it off. If I turn off the pump, the water is all the way inside strainer). I have only one skimmer on( with both it's not at all working).
My question is if there is an air leak somewhere, should I see water bubbles at inlet valves? I guess I don't understand how the air leak works. Does the air circulate or is it simply stuck in the strainer valve or somewhere else?
My husband did mistakenly open the strainer basket to clean and then didn't close it properly and the pump ran like that for a day till I saw. So yes, air went in but I saw huge bubbles coming out of inlets when I bumped the pump next time. Then bubbles stopped. So, I am guessing that air is gone?
Thank you!
Thank you!
