- Oct 10, 2012
- 229
- Plaster
- Hayward Aqua Rite (T-15)
The problem I'm having is the pump isn't filling all the way up. (Hayward VSP) I checked the lid and gasket, cleaned both, and lubed the gasket. I also checked the two plugs at the bottom. I bought a drain unclogger, it attaches to the hose and forces water away from the pump in case there was a clog. The skimmer basket is clean, the impaler is turning. The water is about an inch away from the lid, maybe 2". It doesn't matter what speed the pump is running or if I put it on vacuum, skimmer, or both. Any suggestions on what else I can check?
