I think I have a short across the windings.
Sorry, just realized I did that wrong.Post the ohms from
terminal 1 to to 2
2 to 3
1 to 3.
1 to ground
2 to ground
3 to ground.
1 to 3 should be the sum of 1 to 2 and 2 to 3.1 to 2 - 1.5 ohms with continuity
1 to 3 - 0 ohms with continuity
2 to 3 - it jumps around between 1.5 to 3 ohms with continuity.
You were correct. All 3 terminals to ground read 0.L1 to 3 should be the sum of 1 to 2 and 2 to 3.
Double check the numbers.
0 ohms means no resistance or a perfect connection.
"O.L" means no connection or "Open Line".
1 to 2 and 2 to 3 should be different and 1 to 3 should be the sum of 1 to 2 and 2 to 3.1 to 2 was 1.5
2 to 3 was 1.5
1 to 3 was 00.0
2 to 3 takes longer to settle at 1.5 for whatever reason.
