I think my pump motor has fried itself. No flow and makes a loud humming/vibrating sound and won’t create suction. Problem is no label on the motor anymore just this label on the body. Suggestions on a replacement?
I pulled it a part and everything visually looked fine. Pump sounded fine until i put the impeller back on and then started making an odd noise. Wasn’t hitting the diffuser housing so wondering if it is the shaft seal bearing…
