I have a Pentair Superflo 1.5HP pump. I recently cleaned my filter beacuse I wwas getting filter media back it the pool. I found it had a 2" mulitport valve and a 1.5" standpipe inside, which obviously didn't seal. This allowed filter media up into the valve and chewed up the gasket, which I replaced. I installed a 1.5" to 2" PVC coupling and pipe to properly seat the valve.
Now, I have an issue with the pump loosing prime. When I turn off the pump, water rushes out of the pump back through the supplies. It only happens when the pump has been running for over 10 minutes. Occasionally it will hold water, mostly when it has been running less than 10 minutes, and I see small bubbles come up from bottom of the pump. I may have a very small leak between the pump housing seal plate - its hard to see back there. I did use a seal GO KIT to rebuild it at the beginning of the season. I just replaced the lid o-ring and it seems to seal very well. I have to pour a few gallons of water to get it to prime again.
Any advice on what to check?
