My pump loses prime quickly after shutting down. Once primed the pump if strong with no leaks visible on the pressure side. The pump sits 1’ above pool water level, DE filter with only one check valve after the pool heater. I’ve noticed when the pump is shut down, the filter starts to suck in air if you open the pressure valve resulting in the pump water level being suck up enough where the pump won’t prime by itself. If I disconnect the plumbing prior to entering the multi-port valve it doesn’t do this. If I take the lid off of the pump the water level is just below the pump inlet, if I open the pressure relief valve on top of the filter, water will fill up the pump basket and overflows. I can put the lid back and the pump starts without any problems. There is a lot of air built up in the filter that release when the pump starts. This problem started when I put new DE grids into the filter. I place a check valve between the pump outlet and multi-port valve, made problem worst as now I can’t take lid off the basket and open pressure valve to fill pump basket. After adding the check valve, I noticed a leak in the bottom of the seal plate which wasn’t there prior to installing the check valve. When I shut the pump down there is a lot of gurgling in the pump and filter tank while the water lowers in the basket (lid is still on) Also, there are no air bubbles coming out of any of the return jets going into the pool. I did have bubbles coming from one of the return jets a while back, but it went away after changing the O-ring in the automatic chlorinator!
I changed the spider gasket in multiport valve as well.
Any suggests will be greatly appreciated.
