I have an intellioFlo model 011018 pump it’s just a little over 3 years old. So the other day I noticed it shut off at an odd time about an hour early few minutes later realized we had a power failure. So the pump came back on all seemed fine. Later that day I started the pump manually to clean skimmers the pump had been running for about 30 minutes I noticed major amounts of air coming from the supply jets after a short time everything was fine. So yesterday I started the pump I noticed it was making that priming sound for quiet a while then it shut off. So now I have the red blinking light, some kind of primer warning on the screen. So I took the cover of the pump strainer cleaned it (really nothing much) while the cover was off the pump started didn’t realize it resets. So I made sure the 0-ring was clean and seated properly. Then I manually started the pump it ran for about a minute and then shut off. When I started the pump the strainer was full of water, After about 3 more attempts with the same results I pushed the Quick Clean button and the pump worked fine so I let it run for about 20 minutes then shut it down. So then I tried my normal way to start the pump it just didn’t prime. Now I have all the power shut off to the pool equipment I just don’t want the pump trying to start every 10 minutes. So what I’ve done cleaned all the strainers (really nothing in them) Made sure O-ring is seated on pump, checked filter clamps are tight. Motor doesn’t feel hot. At this point I think the power outage might have affected a setting? But I did get large amounts of air from jets while the pump was running fine. I never messed with the Priming settings. I think the pump is physically good. Any suggestions ?
