- May 3, 2007
- 16,950
- Plaster
- Hayward Aqua Rite (T-15)
Your controller supports two relays but the other relay is for a solar booster pump that comes on 30 sec after solar is engaged. Low speed operates differently and both relays (High and Low) cannot be on at the same time. So unless the controller has a specific low speed mode, it won't work and there is no mention of a low speed in any part of the manual.
In order to control the Intelliflo from another controller, you need an Intellicom unit (~$200) but I am not sure that would work with the AquaSolar.
