Pump/Filter/Heater combination- NEED RECOMMENDATIONS PLEASE
May 11, 2018
1
AB
Hi folks and thank you in advance for any assistance...
My signature provides some basic details about the set up we have. My question is with respect to the type of pump and filtration system we need. The pool came with a FLOWCLEAR 90401 filter/pump. Unfortunately I cannot find the flow rate for this unit. We have just received our new Nautyl 50000BTU heat pump and I need to understand if the pump we have is sufficient. The heat specs ask for a water circulation flow of 83-116L/min.
Also I assume the correct approach is an “inline” one: in from pool to filter/ pump -> heater -> out to pool
Could anyone suggest a reasonable pump/filter or will the one we have suffice?
Thank you
I will leave flow calculations to the experts but I will always recommend my Hayward pump. It has run with a full strainer of water and it has run with barely any water. It just goes and goes and goes.
