Hi,
I have an above ground pool and while vacuuming some heavy debris from the bottom of the pool the sand filter clogged very quickly. I backwashed three times but the last time no water or very low flow came out. The pressure starts around 10-12 psi and tops at 20 psi while filtering. I can still run on filter at around 15 psi but backwash is at 20 and barely spits water out. Normal pressure while backwashing is below 5 psi.
Looks like the backwash is clogged but I don't know how to clean it.
