Hey everybody, I just had my sand filter and pump replaced and although it seems to be working well overall, there is a strange crackling noise around the multiport valve when running on high. It also lost prime a few minutes ago, although I did have the pump off for a few minutes prior. It seemed to prime fine and then pressure suddenly dropped and lost prime a few minutes later. I’ve since got it running again and no issues for about 30 minutes so far other than the crackling noise. I read this could be cavitation, what do you think? Is it possible my new pump/motor is too powerful for the filter I have? The updated information should be in my signature but here are some photos. 15psi seems to be the normal operating pressure. I believe the pipes underground are 1.5”, it looks like they connected everything above ground with 2” pipe where they could though. Not sure if that is relevant. And ignore the poor wiring of the motor, I am having it rewired properly tomorrow.
