Greetings,
I have century 1.5HP pump. Pool is about 6 years old, sparingly used until this year. This year we ran it 4-5 times a week. Summers only.
Indoor pool, so no visible debris, quite clean. Turn the pump and heater for a few hours a day, then shut off.
Pump went bad a few days ago. Humm but no water movement. Company is asking for $600 for parts and labor to replace the pump.
I am trying the new run cap first. 370VAC, 30 microF. A few (silly) questions:
1. Can I use 35microF cap, as it is all I can find now locally. Will this work long term or should I replace it with 30microF ASAP to avoid overheating?
2. The service man said the reason for cap failure is a bad pump. So, even after replacement, it would not last for more than a few months. Is that likely? If it is, I would rather replace the pump now.
3. He also said intermittent use (on/off cycling) is more damaging to the pump that constant use. Is that true? I do not need to run the pump and filter much as it is quite clean and warm indoors. Only use it for a few hours on days I use the pool.
4. Those caps are without polarity, right? Any lead can go to either cap terminal? Also there are 4 individual attachment points on each capacitor terminal. Can I use any of them? Why are there 4 individual "bumps" on each terminal at 90 degree angles.
Thanks very much.
Sincerely,
Sophie
Thanks very much.
Sincerely,
Sophie
