I have a waterfall and some deck jets on my pool. Left it running in freeze protect mode as this was the recommendation from the builder.
One of the skimmers froze up in a way that caused an ice dam and it began to suck some air. This resulted in the pump slightly losing prime and the deck jets of water not clearing the deck into the pool, so essentially it was running itself dry and creating a little ice pond in the yard. The water was freezing so fast I had very little time to react. I chose to shut down all of the equipment, drain it, left plugs out, and vacuumed/blew out the lines and equipment as best I could.
Now, I'm not sure whether to start it back up once the temps clear freezing, or leave it this way since the overnight temps are still forecast to be well below freezing. I'm leaning toward leaving it the way it is until we're well past the freezing temps, because I'm afraid we'll have another arctic blast and we'll end up in the same spot again.
Appreciate any advice.
