So, I was putting JB Water Weld on a hairline crack in my skimmer, all proud of myself, when I lost my balance and feel backwards on top of my pump/cartridge filter housing and knocked them both over. Epic fail. Here is a picture of the damage - cracked plastic 'station', which seems not too bad.....BUT.....now the pump won't start.
Upon further inspection, it seems like the electrical wires from the plug to where the wire enters the pump housing got stretched out or pulled, and this little plastic cylinder at the entry cracked. I'm guessing that wires are loose and/or there is some fail-safe that when there's a problem, the pump won't start. Or maybe something worse.....Edited to add that the pump and filter were lying face down on the ground for 10 min. so there was pressure on the end of the pump. I don't know if the wires in the pic below were like that before the accident, or, happened because of the accident.
1) How do I safely check what the problem is myself (without much experience w/ pumps), in case it's really an easy fix?
2) Are there pump repair people you call when this stuff happens, and are they expensive enough to favor just buying a new pump? This one is only like 3-4 years old according to the previous homeowner, and funds are tight. But safety is priority.
Any help is much needed. 3/4 of my family are in tears. I can't believe this happened.
Disclaimer: I do not use the Aquasmart station, and, I am aware that the weeds need to be removed ASAP from around my pool area.
Kristin
Kristin
