Hi , new pool owner here. Pool company filled up my chlorine feeder with pucks containing stabolizer. Im thinking this is not a good thing as it will continue to add stabolizer until all pucks are dissolved. Im worried that once this happens my CYA levels will be well over max recommended levels. Currently my CYA reading is 23 and I have about 8 pucks inside. Am I going to go over the recommended max CYA level when all these pucks dissolve? I have a vinyl inground outdoor pool. Once CYA reaches a desired level (30-50?) should I try to remove and replace pucks with non-stabolizer ones? Is it even possible to remove pucks safely?
