PSI with new gauge
Zinnia
0
34
Petersburg IL
Installed a new pressure gauge purchased from TFtestkits. Pressure seems to flex between 13 to 15. Is this normal? Backwash when pressure rises above 15. 50% of the time pressure is 15 then it will drop 1 or 2 points.
I don't think I would call it normal but it is not particularly harmful. The most common cause for that pressure fluctuation is a suction side air leak. Do you see any bubbles (pump running) in the pump strainer basket lid?
Backwash at 25% above normal so I would backwash when your psi goes to 18-19.
