DE Filter Pressure Gauge Registering Too Low
jobondur
191
Virginia Beach, VA
Opened my pool and everything was working fine. Then at some point, my DE filter pressure gauge went to what looked like zero. I removed it, cleaned everything up and reinstalled but no luck - still reading zero. I figured I needed a new filter and ordered a nice glycerin filled one from Amazon LINK. I just installed it and it's reading 2 psi when it should be reading at least 10. I removed the pressure relief valve and cleaned it out, but still no luck. I installed the old gauge and same story. What's going on here? Everything seems fine other than the pressure gauge not reading what I expect. Filter is a Hayward DE-6000.
Dirty/full pump basket, dirty/full skimmer basket, suction leak, pump-lid O ring needs lube or replaced, clogged suction plumbing, clogged impeller, water too low in the pool, skimmer weir stuck in the "up" position, hole in a grid, missing air relief in the filter. Your choice, but that's a start.
