Hey all,
Looking for some expert advise on a pool install. Below are the specifications on the setup and last the big questions. See attached pictures for reference if needed.
15'x48" round above ground pool (5,600 Gal.)
Intex SF60110-2 3000GPH sand filter
glass sand media
1" 1/2" pvc plumbing
(3) suction inlets & (1) return outlet:
(1) closed off w/ ball joints - about 3ft or 4ft long from pump
(1) closed off w/ ball joint - about 8ft long from pump
(1) skimmer open full w/ ball joint - about 5ft long to pump
(1) return outlet open full w/ ball joint about 12ft from pump
After a good cleaning (backwash, rinse cycle) my PSI sits around 10PSI. when connecting the vacuum to a suction inlet, opening the ball joint, and closing the ball join on the skimmer, PSI sits at 10 psi.
Question 1: is 10 PSI too low for normal use, with no vacuum?
Question 2: Shouldnt the PSI differe when connecting the vacuum? (manual brush with telescopic pole, or extreme power suction vacuum connected to an open suction inlet)
Question 3: Is there something wrong or does this all sound about right?
Not sure if the pump is struggling or going out or what needs to be done in order to increase psi if needed - runs 12hrs/day. pool sees regular use by myself, and occasionally (rare) rest of fmaily.
glass sand media
