Moved from here.
Hello Tasimm and everyone. I could really use your help. I have spent hours trying to update the firmware on this protocol adapter and I just can't get thru it.
First let me say I'm on a Mac a version of the OSX that has worked in the past when it comes to updating the protocol adapters. But this one I'm really stuck.
The power light comes on and when I plug in an ethernet connection the green and yellow LED light up and flash so I think it is taking at a basic level.
It says Firmware version 5.2.713 on the side.
I did the same thing as last time (see below) and no matter what I do the Pentair Brick Update Utility says the same thing.
I have done the triple paperclip reset numerous times in this process. But someone said that doesn't work on firmware this old.
My first question is when I launch the Pentair Brick Update Utility is wait a few seconds and then it populates under LOCAL SYSTEMS with RAM LOADER (192.168.1.17). Does that mean that it is seeing the protocol adapter and that is in fact the IP address of this adapter?
I have tried both directly into my mac and also going through a TP link router and every time it says the same thing
In the router I'm changing the network to be 192.168.2.1 and also 192.168.1.1 and both failed again.
Does the Subnet Mask 255.255.255.0 need to be changed?
I then launch the app: Pentair_Brick Update738 and it says:
Local Systems
So I select it and then hit START
It gives me the following:
Starting Update Procedure
System type: Edgebrick - Pool
Getting Brick Config...
ERROR: Cannot get brick config
Any thoughts or ideas?
I'm hoping someone can chime in here with some ideas on how I can get thru this.
Local Systems
