I feel like it’s a little unorthodox, the way you have it(from what I’ve seen) I do think it will work. But you would have to sacrifice individual control of each bubbler and laminar features and just have them run at the same time. I feel individual control is easier achieved with an additional pump(s) and actuator(s). Doing it all with one makes it much more difficult. You would have to have one actuator after the other opening and different speeds attached to each feature, the risk of higher speeds overwriting Lower speeds. and you would have to adjust when the filter gets dirty. I feel like the complication is not worth it. But it’s not my pool. If you are happy with the design I would make the T after the filter a 3 way with actuator and keep the 3 way in the middle a manual, so you can adjust once and that’s it. The actuator will turn features on and off.
