I was thinking about buying one of those propane tank gauges which tell you how much propane is left in the tank. Do they work, are they accurate?
TY!
Dan
TY!
Dan
DCAG said:Thanks all!
John, those stick on ones, I'm guessing they only show the level while you're using the tank, because it reads the temp of the tank, right?
Or when you pour warm water it'll show the level of a tank regardless?
Dan
Bama Rambler said:Your best bet is to get cylinders with float level gauges built in. They're the most accurate. I've never had any luck with those pressure type gauges. They never let you know you're getting low until you're out and then it's too late.
Here's one place to get them.
Amen,,I stopped getting the tank exchange because you don't get has much gas..Just started filling them up myself..Has far has the gauges.Had one inline for about a yr.Using grill one evening&showing out of gas&was acting like it was out of gas..So unhook'd the gauge & stiil had plenty left..Don't know what was wrong..But, they are nice to have when they work.techguy said:I know this is only slightly related but I was doing some propane shopping recently and the subject of exchange propane tanks came up. I know the having my tanks filled is more cost effective but the exchanges are quick and easy... and a rip-off. When they started doing tank exchanges they were adding about 18 pounds of propane by weight. The difference is now the exchange bottles are filled to 15 pounds and are the same price or more. I have heard the tare weight of the bottle is not always taken into consideration but I doubt that.
Do your self a favor, get two bottles and have the rental yard or gas station fill them, but confirm they do not have either a flat-rate or $20 minimum charge per bottle.
techguy said:Do your self a favor, get two bottles and have the rental yard or gas station fill them, but confirm they do not have either a flat-rate or $20 minimum charge per bottle.
Exchange at wally world&other exchange you are not getting full amount of gas than taking to somewhere&having filled on the spot..So it is costing more moneyDCAG said:techguy said:Do your self a favor, get two bottles and have the rental yard or gas station fill them, but confirm they do not have either a flat-rate or $20 minimum charge per bottle.
That's what I used to do. A couple of seasons ago, I found a coupon to have a tank filled for $10. So we went to that place, and had the tank filled. I think that tank lasted two grilling sessions. I wasn't happy, and haven't gone back there. Now, I usually exchange my tanks at Walmart for $20.
I still haven't bought gauge.![]()
