Former owner seemed to rig this to work and it got hit by a excavator which cut a cord, the other actuator then shorted and almost melted the connectors together before blowing the fuse. Managed to get that out and replaced both actuators and the fuse. I can get them to spin working the switch and in some instances get them to work one direction one time only. The violet wire was disconnected which i reconnected while troubleshooting.
the only thing that I could see bad was no voltage across the orange wires even tho the fuse has been replaced. Would a bad rectifier cause this or a bad board?
