My pool/spa was built 10 years ago and it's worked fairly well with notwithstanding the typical problems. However, last season I had the spa side remote replaced as it was cracked. They used a fair bit of the slimy wire pulling lubricant, some of which went into the water. Although I do think most of it was scooped out. This may not have anything to do with my issue but I thought I'd mention it. Since that time the spa no longer works correctly. Sometimes when you turn on the jets you get no air bubbling and fairly weak jets. Sometimes you turn it on and it seems relatively normal. I've had two companies come and look at it. The first one said I need to add a spa blower. The second company said they will blow out the line with compressed air and that will fix it, which it didn't. They then said I need to add a spa blower. I should note the second company is the company who built the pool in the first place. They said over time the lines will build up calcification and the only way to get more air to the spa now is to add a spa blower. I don't know what to think. It worked fine up until a point and now it's hit and miss. My variable speed pump has been tested and it's also fine (pentiar). So I'm looking for suggestions or validation that I have no other option other than to add a spa blower.
Thanks to everyone.
Thanks to everyone.
