I've been running my pump at 1100 rpm lately and we had a big wind storm so I cranked it up to clean the pool out.(it had a ton of leaves after the storm) It worked fine yesterday but then today when I was cleaning it with my net, I hooked up the floor cleaner and the pump primed for 10 mins and then failed. The pump basket is full of water so I don't understand why it's failing. I'm a relatively new pool owner so I'm not sure what's going on. I disabled priming on the pump and turned it on and it's working fine. I'm not sure if priming is required if the pump basket is completely full with water or if I did a bad thing by disabling priming. from what I read online, it says there might be a problem on the suction side of the pump. maybe debris is clogging it somewhat and that's the issue. water flow seems to be fine. maybe it's an issue with the pump itself? I've never seen that many leaves in my pool as I had today so I wanna lean more towards the leaves being the issue. Any help for diagonising is appreciated
ps: not sure if it shows on my profile. it's a penatir intelliflo 3hp vs pump
