- May 14, 2013
- 159
- Plaster
- CircuPool RJ-60
Hello, I’ve been reading previous threads about prime speeds with VSP’s. I have an Intelliflo VSP. My pool pump and equipment is far from the pool, above it, and there are a lot of twists and bends. The prime speed came defaulted at 2500 but I have a lot of air in the system that doesn’t clear. I need to normally run my pump at around 3000 to keep the waterfall flowing and pool cleaner moving. Can/should I set the prime higher to clear that air and get it moving better? How high can I set it safely? Thanks.
