preventing critters from chewing on sand filter drain pipe after closing
ba67
130
Southern Kentucky
Fiberglass
This year when we opened up our pool, we discovered that a critter of some kind chewed on our sand filter drain cap over the winter. It couldn't be fixed so we ended up having to get a brand new sand filter which cost over $1000. Our pool is going to be winterized tomorrow and I was wondering if anyone has any suggestions for me on how to prevent this from happening again. My pool pro suggested that holes could be drilled into a replacement drain cap so water can drain out but a critter won't chew on it. Does this sound like it would work or could the cap trap some water in there that could potentially freeze and damage the sand filter? Does anyone have any other suggestions on what could be done to prevent another critter from chewing on the drain cap again? We back to a field so we have a lot of critters around here that like to chew on things. I will attach a picture of the damage that was done last year so you will know what I'm talking about.
  • Wow
Reactions: JamesW and Newdude
Can you put some type of metal box around the area for the winter to keep critters away from it?
Or put a metal fence around the area.
Reactions: ba67
+1. Cage it up with fine mesh chicken wire (1/4 inch ?) Anything that can still get in really can't do any harm.
Reactions: ba67
Maybe get a brass threaded coupling to screw onto the threads to protect the thread.
I think that a NPT or NPSM thread should work.
Get a 1" pvc threaded fitting to try on for size and then get the brass fitting once you know the size.
Don't damage the threads.
Just screw it on until snug, but not tight.
Below says that it is a 1" fitting with 11.5 threads per inch, which is standard NPT.
I contacted Hayward and here is the thread size and type: 1" x 11 1/2 NPSM with Higbee start. I just need to find an adapter from NPSM to NPT or any other hose thread.
NPT – American National Standard Pipe Tapered thread.
This type creates a pressure-tight seal, which occurs when the male and female NPT threads compress and tighten.
NPSM – American National Standard Pipe Straight Mechanical Joint thread.
This type creates a non-pressure tight connection in applications that are not subject to internal pressures.
Both NPT and NPSM connectors have the same number of threads per inch, and the angle of each thread is 60 degrees.
The obvious difference between NPT and NPSM, as their names indicate, is that the former is tapered (slightly conical) while the latter is straight (parallel).
Maybe something like this?
SharkBite 1-in PEX x 1-in NPSM Brass Female Swivel Adapter
If you use just the brass threaded part, that should protect the threads.
Thanks for taking the time to post this suggestion and picture. I couldn't find any brass couplings like these at my local Home Depot or Lowe's but I found a hard plastic threaded cap with a hole in the middle that came off of an old gas can that looks just like it. It screwed into my sand filter drain pipe perfectly so it should protect the threads and it allows water to still drain out since there is a large hole in the middle. I think a brass coupling would provide more protection since a critter is less likely to chew on brass than plastic so I'm planning on ordering one to see if it will fit on my sand filter drain pipe.
