After moving to a two speed pump last year I ended up reducing the size of most of my returns so that the pool would have some circulation when the pump was on low speed.
The side effect of course was to increase the pressure on the return system with my DE filter guage going from 18psi to 25 psi (both readings taken immediately after filter tear-down and cleaning.)
My question is: should I be concerned with the additional pressure and put in a couple of larger returns or not worry since the filter is rated to 50psi max and there's no indication of other issues? The pool is crystal clear so there's no other driver for this question other than equipment wear and tear.
Thanks!
Thanks!
