Pressure gauge question
nanobooboo
22
Cottageville SC
I have a trap door installed in the deck and can't see the pressure gauge from the topside. I will get the glycerin gauge for sure, but wondered about using a 90 degree elbow...I want the fitting to come out of the filter, and then attach the gauge so it's facing up toward me. Will that significantly impact the accuracy? I am more inclined to view the PSI as a relative reading versus scientific reading...
jblizzle
43,238
No issue doing that. In fact there was another thread discussing using long pieces of pipe to run the gauge away from the filter so it would be better read.
Bama Rambler
23,874
I personally prefer stainless steel, but it really doesn't matter with these gauges. However, I recommend you get a 0-30 psi gauge instead of the usual 0-60 psi. You could also get a bottom mount gauge and wouldn't have to have the elbow.
Bama Rambler
23,874
I believe you mean "back mount". 😉
Nope, I meant bottom mount. :)
If they're wanting to use an elbow to turn it up to where they can see it from the deck they most likely have a back mount now. Back mount gauges are common on sand filters which they also have. My suggestion to get a bottom mount gauge would allow them to screw it into the multiport and turn the dial up so they could see it above the deck without an elbow.
nanobooboo
22
Cottageville SC
Great idea...I was making it more difficult than necessary! So will the dial that came on the original gauge come off and be usable on the new glycerin gauge or do I need to shop it further?
SPenfold
61
LI, NY
You are correct, I didn't see sand filter.
Bama Rambler
23,874
Assuming that you're talking about the movable ring around the face of the gauge, the new ones won't come with that, and that one won't transfer to the new gauge. You don't need it anyway, because you want to adhere to the 25% rule of backwashing rather than the 10 psi that the gauge ring is marked with. Most of us clean the filter and then write the pressure down and clean the filter when the pressure rises 25% above the clean pressure.
nanobooboo
22
Cottageville SC
Assuming that you're talking about the movable ring around the face of the gauge, the new ones won't come with that, and that one won't transfer to the new gauge. You don't need it anyway, because you want to adhere to the 25% rule of backwashing rather than the 10 psi that the gauge ring is marked with. Most of us clean the filter and then write the pressure down and clean the filter when the pressure rises 10% above the clean pressure.
[/QUOTE
MickWein
16
Chicago/Illinois
You're saying a bottom mount gauge will work just as well in a recessed back mounted filter hole? If so, would I need an extension to clear that recess in the filter lid? And for giggles, anyone know the correct size or are the post fittings standard?
In case my info is missing: Hayward Extreme 1500 series cartridge filter 🥴 Thanks in advance.
