Hi all. I bought my first house and it has a pool. Used a neighbors pool guy for a couple months but realized that was a bad idea. We installed a vacuum cleaner (AquaNaut 250) and had the pump running ~10 hours a day at night. After reading some stuff, I realize that I can probably run it 4-6 hours in the morning (better for my schedule to adjust chlorine then) and I also don't need to run the vacuum cleaner all the time. He was also backwashing every week which is not necessary.
I went to adjust the Jandy valve from about 75% vacuum cleaner/25% skimmer to 0% vacuum/100% skimmer and the pressure dropped from about 15 PSI to 8 PSI and I heard hissing from the Jandy valve. I have a Jandy "never lube"...can I still replace a seal to see if that solves the problem? My understanding is that I should be able to run the pump with 100% skimmer no problem and the PSI should be about the same. Is that correct?
Also, my PSI on the filter is not raising. It's stayed at 15 PSI for weeks...could be a product of this likely small air leak?
