I have a reoccurring situation that I can't find an answer to.
When I am using DE in my filter, which i do occasionally, I normally let the pump run until the pressure rises to a point where I feel I need to backwash. This usually happens in about 10 hours or so. My nominal pressure is 12 psi and backwash at about 18 psi, when using DE.
The head scratcher for me is if at the 18 psi point I turn the pump off for a few minutes and back on the pressure will return to 12 psi. I have tried this a few times and the same thing happens. I just cant figure out why the pressure wouldn't return to the same pressure it was before I turned off the pump.
Any ideas? Thanks in advance.
