I have a 15' x 30' above ground pool. The liner was removed several years ago and it went from being an above ground pool to an above ground planter. It filled with grass, weeds and tree saplings.
I'm in the process of cleaning it out in preparation for a new liner. I have pulled all the weeds and saplings up by their roots and will treat the area with Roundup to kill the grass including nutsedge. I will then remove all the debris and smooth the sand.
Instead of putting the liner directly on sand as I did initially, I will use rigid foam and/or a pool pad. I will use foam coving instead of dirt that I initially used .
My primary concern is to keep any plants from harming the liner.
Here are my questions:
1. Since I am using foam and/or pad between the sand and the liner do I still need to apply nutsedge killer on the sand?
2. Would there be any advantage to using foam and a pad? Do they both block nutsedge? Would any other plant grow from the sand?
3. What thickness of foam 1/2" or 1".
4. What's the best pad? Gorilla, Rhino ?
5. What size cove?
Any answers and comments are greatly appreciated.
5. What size cove?
