Hey there! New member here, trying to soak in all the info I can. I've talked to a couple builders and have a preliminary quote, wondering if you knowledgeable folks can give me some feedback. I'm in central Arkansas. Vinyl lined, 3ft-6ft deep. Easy access to the yard.
PB1:
Vinyl Lined, 18x36 freeform (kidney shape).
1 jandy LED color changing light
8 tab cholorinator
jandy sand filter
1hp jandy flow pro pump
2 skimmers
2 returns
main drain
4ft of deck around perimeter
$7/sq ft for additional decking
$39k + $4,500 for cantilever coping (stamped/stained), +$3,500 for vinyl lined steps.
no swim out bench, says the liner doesn't typically hold up to them
$47k
PB2:
vinyl lined, 18x37 freeform ('mountain oasis' shape)
vinly lined steps, swim out bench in one of the small curves
2 led color changing lights
300lbs sand filter
1.5hp pump
1 skimmer
2 main drains
3 returns
cantilever coping
4ft decking around edges, 6ft decking on each end
$5/sq ft for additional decking
$47k
Both PB's require I pay electrician directly, estimated +$1,500.
I asked both builder's about plumbing/conduit for extra deck jets, water features, LED lights, so that I could add them in the future. PB1 said needed to put them in when built, PB2 said plumbing for extras is no problem and wouldn't cost anything.
PB1 says they strongly encourage tab cholrinators and not SWG, and said variable speed pumps aren't necessary and wear out more quickly.
PB2 says they only usually do salt on 8ft deep ends or more, with a cell sized 2x, and encourages a variable speed pump (+$800 for the pump).
Additional lights are +$800, deck jets are +$600.
PB1 is about 8 weeks out plus 3-4 week build time.
PB2 is about 7 weeks out plus 6 week build time.
We have a third builder coming out next week, but I'd like some feedback from you guys if possible!
Thanks!
PB1:
8 tab cholorinator
jandy sand filter
2 skimmers
2 returns
main drain
$47k
PB2:
300lbs sand filter
1.5hp pump
1 skimmer
2 main drains
3 returns
cantilever coping
$47k
Thanks!
