Based on all the manufactures out there, what hydrotherapy spa jets are preferred for new pool / spa builds and also what setup did you all use to allow for calm water flow through it, churning the water, or fast flow through the nozzles?
Coming from a Bullfrog A7 with the jetpaks was amazing but would like to know what spa jets for new pool/spa build folks recommend that are close to hydrotherapy / adjustable?
I would like to ensure we have all those options.
This is our current draft equipment list
- Pool Pump -- Pentair Intelliflo VSF or IntellifloXF VSF
- Spa Pump -- Pentair Intelliflo VSF or IntellifloXF VSF
- Filter -- Pentair DE Quad 100 sqft with NO backwash installed
- Heater -- Pentair ETI400 or Hybrid or Mastertemp 400 BTU
- Controller -- Pentair IntelliCenter i10PS
- Valves -- Jandy "no lube" Valves with Pentair IntelliValve Actuators
- Check Valves -- Jandy check valves
- Chlorination System -- Pentair IntelliChlor (IC-60)
- Dosing System -- Pentair IntelliPH
- Lighting -- Halco Lighthing ColorSplash line (12v or 120V) or Pentair MicroBrites
