Pre pool opening (white water mold)
I’m getting a tad further
Was able to get intelliconnect to connect to phone but when I put in the wifi password (says signal strength excellent) it saysIMG_5745.jpeg
Did you try again?
You may have fat fingered your password.
Yes multiple times and I touched the “eye” so I could see password . It was correct .
In reality I don’t care too much if I can use the app or not . Sounds like it really only works for the lights (with my pump) . Long as the service mode on alll the time isn’t causing any issues
You get none of the benefits of having the IntelliConnect without having the app connected.
Right now your IntelliConnect is worse then a dumb switch. It is doing nothing for you.
What Wifi router or Access Point do you use>
Would a pic of the router work?
I can’t really answer that question .
I’m Very UN techy
We are in a rural area and use a local Remc for wifi service and it’s fiber that’s about all I know
I will get that to you shortly.
While I am thinking about it, when I was trying to connect today (after reading the link you shared)
my flashing link light does not seem to blink 10 min, the pentair home app says it will, then turn red if not connected. Mine stays solid green after a few min (idk if this is helpful info for you or not)
My link light is solid green right now.
It only flashes green when I flip the breaker.
When I open the app it says no devices
I try adding the intelliconnect
Get through the pif number
Allowed access to location
Chose my wifi
Entered password (multiple times correctly)
Keeps giving the “home app can not connect with wifi please try again”
So this means the intelliconnect is connected to wifi but there is an app issue ?
Got most stuff set up in the app.
I can turn the lights on and off but can not change or control them. Maybe I entered the wrong brand?
The pump WILL NOT RUN in auto mode. It will only turn on in service mode
You are making progress figuring the system out.
I think you need to tell the app what relay the pump is connected to.
What have you done to tell it your configuration setup?
When In auto mode there is no display on the pump and I can not turn it on manually . It only powers on when I press relay 2 (pump) and switches to service mode
