- Jun 20, 2019
- 37
- Plaster
- Pentair Intellichlor IC-60
Planning to install a new 3hp intelliflo VSF I purchased last year to replace our current 2HP Hayward single speed skimmer pump after this pool season, (will allow me to run skimmer more hours at lower RPM), *would it be crazy or good idea to swap out the brand new OEM shaft seal with one of the PS-1905 seals before I install this new pump?
Also I am thinking to overhaul our current identical 3hp VSF pump that has been in service for 3-4 years, this pump is running great and not leaking currently, but I was thinking to be proactive to install the PS-1905, new gaskets, anti-seize all the bolts, etc., is this a good or bad idea to do proactive pump overhaul?
After reading advice here I was planning to anti-seize all the bolts on the new pump before installing anyway, so I was thinking it wouldn’t be too much more trouble to open it up, fresh lube all the gaskets, and can install PS-1905 shaft seal, hoping to maximize lifespan and serviceability of this new pump, does this sound like a good plan?
I am hoping after installing the PS-1905 seals on all my pumps I can just watch them for leaks and hopefully get a lot of years out of them before servicing again, but wanted to ask is anyone here doing preventative pump overhauls every few years? How often should I be doing preventative overhauls if PS-1905 seals are installed in my pumps?
Any advice greatly appreciated,
Happy 4th!
Happy 4th!
