I am running new 240 volt wire to my pool. It will be used to power a Pentaire easytouch 4 with ic40 SWG and a Pentaire intelliflow pump. I thought AWG #8 providing 30-40 amps would be more than sufficient but the easy touch install manual says AWG #4 for a minimum of 60 amps is required power input.
Why the 60 amp requirement and can I get away with #8 AWG into the Easytouch?
Also should there be intermediate junction box with cutoff switch for power into easy touch or does Easytouch have a built in power cutoff switch for the pool equipment?
Our pool is in San Diego.
