Hi,
I am noticing what I thought was sand but worry is potentially tiny blobs of algae on the bottom of the pool over the last days and weeks. I would brush it or robot vacuum and it would seem to return in the same areas. No CC readings really ever, but I'm reading that is not necessarily indication that I don't have algae. Decided to SLAM. Preslam readings are:
FC 8.0
CC 0
Ph 7.9
TA 75
CH 225
CYA 70
BOR 36
Temp 69
Salt 3800
TDS 4250 ( - this one from electronic device I have)
I lowered PH down to about 7.5 prior to slamming. Didn't confirm that with a test but added enough MA and assumed. Slam is 28PPM so I added what eventually became about 18L of Walmart (6%?) bleach just to get up to 27. Seems the Bleach is weak as I am consistently adding more than what is being suggested and still falling short (date code shows a month old only..) I've been holding more or less around 25-26PPM with Super chlorinate on and adding Bleach consistently just to keep it there. Still zero CC's so I assume FC is evaporating off rather than burning through contaminates...
OCCT loss was 1.0 last night, but I still see what I assume is algae popping up on the bottom (see attached).
Still FC seems to be burning off very quickly during the day so I tested CYA and suddenly CYA is 50. I don't understand how I could have lost 20 CYA in two days with no backwashing? I'm using DE in my sand filter and Borates this year for the first time. Also a liquid solar cover but that was in use last year as well.
I feel like there might be some kind of strange interaction happening. Also, surface of the pool seems just a bit glassy or oily the last few weeks. It's actually sort of pretty so I assumed maybe this is related to the Borates or the Liquid Solar cover that sits "on top".. possibly not related to my issue but just throwing out everything I can think of. We've had a couple rodent deaths in the pool the last few weeks but dealt with quickly and again, no CC.
Any ideas what happened to my CYA or what the deal is with algae (if it's algae? )..Do I just keep trying to SLAM for a while to see if it goes away?
FC 8.0
CC 0
Ph 7.9
TA 75
CH 225
CYA 70
BOR 36
Temp 69
Salt 3800
