- Dec 26, 2019
- 1,995
- Plaster
- Pentair Intellichlor IC-40
Alright, I think I'm fighting a suction leak and I'm looking for any opinion/guidance to make sure that I'm not overlooking something simple, or that I haven't missed anything. This has been an ongoing issue that I have been trying to find for about 6 months, so nothing extremely new after the recent polar vortex*.
Issue is with my filter pump. I can open up my leaf cannister and pump, fill with water and start-up, and can purge all of the air out of the system. The priming speed will get most of it, but since I have an IFCS, there is quite a bit trapped in the zone valves that takes a little while to push through. I run my IFCS system @3200rpm. Then, when the system slows to 1600rpm, which is where I run the rest of the time, for SWCG operation, the water level in the pump basket will drop. Next day, when the IFCS kicks on, rpms increase and it will fill the basket, but it aerates the water, and I get tons of air coming through the lines. One thing to mention is I ran my pump @ 3200rpm during the entire 2 weeks of freezing weather we just went through and I had just one or two small air bubbles in the lid, no aeration to mention and no air bubbles through the return, so it appears to only happen when the rpms reduce.
*I will say that my spa suction line began to freeze up a few days in to the 2 weeks of freezing temps and when freeze protection tried to shift to spa, my pump went into priming mode and was mostly starved for a few minutes. This happened several times, while I was sorting things out as to what was going on. Not sure if any damage was done to the pump due to that, but it seems that the drop in water level is more significant since that event. It also appears that there is more aeration in the pump basket when it is full, than there used to be. Here's a video of what it looks like @ 3200rpm.
Pool was built a year ago, so equipment is all just over 1 year old. I reworked my pressure side plumbing from how my PB had installed it, but haven't touched the suction plumbing. I have examined and lubed the leaf cannister and pump lid o-rings several times with no luck. I've checked and lubed the drain plug o-ring, and the pump union o-rings. My next step is going to be opening up all of the diverter valves and examining the o-rings for them. I had not done this yet as I struggled to believe that a diverter valve that was less than 1 year old could have messed up o-rings. But that is the only thing I can think to look at next.
Am I crazy to think that the pump basket shouldn't lose water at all? My water features pump runs @1200rpm and stayed completely full all through last summer, through several opening and closing of the lid, to clean the strainer basket. I winterized my water features so I have not yet fired that system up this year to see how it is doing.
Is there something on the pressure side that could be sucking air? Generally I wouldn't think so, everything I know about hydraulics would say no, as pressure side leaks generally spray fluid, but thought maybe I'm missing something there.
--Jeff
--Jeff
