- Apr 4, 2015
- 31
- Plaster
- Pentair Intellichlor IC-40
UPDATE - So I feel like I've done everything I can do and I still have bubbles - but I'm guessing that it's normal and I'm fighting a phantom issue.
I've replaced both diverter valves and lubricated the o-rings.
Replaced O-ring on the cartridge filter and lubricated.
Replaced O-ring on the pump filter basked lid and lubricated the O-ring.
Replaced and lubricated the O-ring on the drain valve on the pump.
Replaced the vacuum hose.
I was running the pump at higher RPM's do compensate for a failing chlorinator - until I could purchase the new one.
Since purchasing the newer chlorinator and installing it, I am running back at 4 different schedules with lower/adequate RPM's for the correct turns per day.
We are right back at this -
diverter turned to drain and skimmer with skimmer basket in - NO VACCUM - run perfectly - no bubbles (no bubbles)
diverter turned to drain only - NO VACUUM - runs perfectly - no bubbles (not even small ones)
diverter turned to drain and skimmer with VACUUM HOSE attached - bubbles
diverter turned to drain only with VACUUM HOSE attached - no bubbles
diverter turned to skimmer only with VACUUM HOSE attached - bubbles
So my deduction is this - either my hose is drawing air in or there is some other weird problem. For now, I am just going to live with the fact that I am probably overthinking this whole thing.
Thank you for all the replies and attempts to help me with this. I'm sorry I don't seem to have a solution.
