Hi All,
I've been monitoring water level drops on and off for the past couple of years. This time I think I have possible evidence of a leak somewhere. Long story short, when I keep the spa return running all the time (8 hours a day now), I see 1/2 inch drop of pool water level in 2 to 3 days. Temps have not been really hot these past days, and humidity has been above 50%. In the past 2 weeks I have also noticed that the spa is losing 4 inches of water overnight, when the return valve is open. On Sunday, I closed the return valve and programmed the spa spillover to run 15 minutes a day. Since then, I have not seen the spa water level dropping more than half an inch overnight.
Could this be evidence of a possible leak on spa return line? I guess, only a company with the right tools can tell for sure?
Some pictures attached.
BTW I call the spa return the pipe that pushes water from the bottom of the spa up. The spillover lines would be the jets. Sorry I am not using the right terminology.
Thanks
Thanks
