I opened my pool and all is fine (clear). Too cold to swim here so just been keeping my CH and PH on target. But, I put my solar cover on and I’m wondering if I’m creating a problem. During the season, the cover doesn’t stay on very long because we take it off often so we can swim. I’ve had the cover on for a while (more than a week), and I see two things. One, there’s leaves and stuff on top and the edges of the cover. Of course the skimmer doesn’t work on that stuff with the cover on. Second, the cover doesn’t lay perfectly flat so there are some puddles of water on top of the cover. Of course, this is not chlorinated water. Today I look out and the water on the cover seems a little cloudy. So:
Am I correct that this is a problem, possibly a big problem? There’s really no way to get the cover off without this junk getting into the pool. Is it too little to worry about, or should I plan on adding a lot of chlorine? I’m thinking I need to take the cover off, leave it off until we start using the pool, clean it up and then do a OCLT. The water is cold right now (around 50 degrees) if that matters.
