Pool was installed last year, this is the first year opening myself.
After removing winter cover, I noticed the pool liner had water behind it and was floating in section of the shallow end. I detached a portion of the liner, pumped out the water, filled the pool and gently brushed the liner back into place.
After filling I noticed regular bubbles, although insignificant in size, they were steady. I also noticed a small air bubble forming in the top of the pool pump and also, I noticed a couple times the pump would lose prime. Eventually, I found a leaf between the oring of the pump cover and had believed to had fixed my issues as I no longer saw bubbles quickly forming in the pool pump top again.
Today after a large storm, I found a large bubble once again in the pool pump top, but both skimmers were completely full of leaves and debris. I removed the debris, primed the pump, and once the Jets began flowing, a large plume for each return shot out dirty brown water and then cleared after 2-3 seconds.
The pool builder didn't backfill the pool walls very well, and only used the native clay soil, removed from the hole originally. My concern is that there is a leak and that was the source of this brown water shooting from the Jets once I turned the pump back on.
Any thoughts?
19,000 gallon lagoon
Superflo VS
Tagelus sandfilter
Intellichlor swg
Easy touch control
Any thoughts?
Superflo VS
Tagelus sandfilter
Intellichlor swg
Easy touch control
