Since last year, we have had issues with our in ground pool. It is a 17,000 gallon (approximate). The problem is being able to get the pool pump going. Prime starts up but water has trouble coming into the pump. The pump is elevated several feet from pool. The elevation could be contributing but it worked fine for the first 3 seasons we owned this Penntair VS pump. We got it going yesterday after many tries. This successful attempt required plugging the skimmer while the pump was priming to build up lots of suction. We also closed the valve at the pump. It got priming and ran for a few hours then lost prime. Last year we had a leak detection company come in to find a leak. They fixed one apparent leak but that ultimately didn't correct the problem. We couldn't afford to bring them in for more detection attempts (very expensive). I got the system working last year but It took great effort (did the plugging technique). Is this a pump issue or is there likely a leak? Is there a product we can dump into our skimmer to perhaps seal any leaks in the system? Any ideas? Elevation? What else could it be.
