Looking at a possible first build and was curious if anything looks off or needs changing. May still manipulate the shape to fit the backyard in the best way and will add more pictures as I get further. Picture shows square but have modified already to be rectangle. He does include standard on his pools the A&A cleaning/circ system (which I realize a lot of folks don't like) but said in his mind its for circulation of the pool and heating and not necessarily the cleaning.
So far:
24'x16' (80' perimeter) 3.5-5
8'x6' spa within the 8' perimeter 3.5' depth
Steel/Gunite (lifetime limited)
3/8 rebar 8" OC
4000PSI Gunite 6 1/2 sack mix
6" minimum walls, floors
8" minimum coves
12 minimum beam with 4 box beam 1/2" rebar
Plumbing (2yr)
plumbing 1.5", 2 and 2.5 unless specified
10-15 lb pressure throughout
jandy neverlube 2x2 1/2"
autofill 3/4 line tied to residence hosebib or other
2" overflo
6 directional inlets for circulation
1 8" pool main drain
7 spa jets
1 spa return
1 spa drain
Finish
pebble sheen (10 yr)
travertine tile coping (2 yr)
6" band of tile at waterline (2yr)
Equipment (3yr)
Jandy Plus HP 2.7 Variable
Jandy Multistage Booster
Zodiac Polaris 280
Jandy CV 460 Cartridge Filter
Jandy 400,000 BTU NG Heater
Jandy 1.5 HP Spa Blower
IAqualink PS4
Nature 2
2 LED light poool
1 LED light spa
Intermatic Transformer
Concrete Decking (2yr)
Salt Finish
So far:
3/8 rebar 8" OC
8" minimum coves
Plumbing (2yr)
2" overflo
7 spa jets
1 spa return
1 spa drain
Finish
Equipment (3yr)
Zodiac Polaris 280
IAqualink PS4
Nature 2
2 LED light poool
1 LED light spa
Salt Finish
