I attached some pictures of the completed project as well as a few build photos I found. Long story short, the wet deck has a bubbler with a built in LED Jandy light, this version: Nicheless LED Pool Lights | Jandy
After the build was complete, the light in the bubbler started fading quite a bit, until the point where it wouldn't turn on. The project was completed in late September, so by the time we found out about the issue, we were closing the pool for the winter and were told it would be addressed in the spring. They sent a crew out to replace the light, they unscrewed it from the PVC, but then pulled so hard on it trying to get it to come out that they broke the light loose from the wire. They went to the junction box and tried to pull the wire out that way and it would not budge. They suspect the conduit is crushed somewhere. I put an inspection camera in the pipe and can see the wire broke clean on the wet deck end, so there's nothing on that end that would prevent it from sliding through. I would guess it's about a 90' run. From what I can see, there's exactly 360 degrees of conduit angle, so I don't believe they violated the "four 90's rule".
At this point, it's turned into a finger pointing blame game. The company we paid for the pool is blaming the contractor they had install the pool, he's blaming the hardscaper for crushing the conduit, and the hardscaper is saying that's "impossible". I'm not sure anyone will take on responsibility for the replacement of the light.
I tried pushing a fishtape through the wet deck end and it got jammed up pretty good at about 3', but that doesn't necessarily mean anything as I know it can be very difficult to push a tape through conduit with existing wires. . My hunch is the pool installer did not allow enough room for the conduit in the gravel bed when they dropped in the wet deck and it kinked the conduit. You can see in the build photos that there isn't any room for for the conduit, but that's also true for the PVC, and there's no issue with the bubbler, so I could be wrong.
I really can't see any simple way of fixing this. There's a 4' concrete base around the pool and wet deck, so removal of the wet deck isn't as simple as just removing the pavers. I'm hoping someone here has a good idea for a simple fix. It's just a light, so at the end of the day it's not a huge deal if I can't get it to work, it's just really disappointing and without the light, the whole pool area just seems like something is missing when it's not lit up, but maybe that's just my opinion.
