I've read a number of threads on this topic, and just have a few remaining questions. Planning to purchase the On The Go portable RV water softener, probably the Park Model. Our water fill is basically manual, though controlled by a sprinkler valve so we can schedule fill time/amount via irrigation software.
1. Assume the sprinkler valve should be on the input side of the softener tank. Please confirm.
2. Do we need a Back Flow Preventer on the outlet side? The 48" tank base would be above pool level, but not sure that matters.
3. Does the softener tank need to be inverted to drain as part of the regen process? If not, how often does it need to be inverted? Just trying to plan how "portable" to make the install, plus, 50lbs is not the easiest to move around.
Thank you.
Thank you.
