Above ground 15x30 pool. Hayward pump and sand filter.
There is very poor water flow coming out of the return. The flow is the same on all filter settings (filter, recirculate, backwash, etc.) I have tried every fix suggested by Google but nothing has worked.
Backstory: I had an algae issue so I used Green to Blue to clear it up. When I attempted to vacuum to waste, I could not get any suction going. I had a pool company look at it and they suggested replacing the pump and filter. My pump and filter are less than a year old. Instead, I changed the pool hose connecting the skimmer and pump and I changed the sand in the filter. I was then able to vacuum to waste successfully.
After vacuuming, I tried to filter the pool but I can't get the water to flow through the pump/filter system. The return water pressure is very low. The water flow to the pump is very low. I have primed the pump, water level is good, baskets are clean, nothing around the impeller. I tried to back wash and rinse. The flow of water out of the back wash hose is very slow. I'm at a loss!
