My spa had a 1hp blower. It died and I wanted more air flow so I went with a 2hp. Wow did I get some air flow then, but it was a little too much. Then I had an idea how to reduce the air flow for about $5. I bought one small PVC pipe and one PVC coupler. I stuck them together and drilled a small hole. I kept widening the hole until I got the desired output. My final hole is about the size of a pencil. This does add a little bit more noise to the blower because you have the sound of the blower plus air coming out of the extra hole. I put duct tape on it but don't be alarmed, it's not going to fly apart. I had to beat those pipes together (I saw no reason to make it permanent).
Maybe this will help someone else down the road.
