My deck used to drain well around my cage perimeter, through the V groves between the paver edges.
About a year ago, I swept in some new sand with polymer to fill in some gaps between the pavers throughout the deck.
Some of this sand w/polymer eventually worked its way under the cage bottom plate (the bottom of the cage) and hardened so water cannot drain through the V groove under this cage plate.
A pressure washer will not blow this out.
How do I get this hardened sand out of the paver grooves so water can drain under??
Has anyone dealt with this before?
Thanks!
Thanks!
